How to: Install a Manual Fan Switch for the 06 - Honda CBR1000 Forum : 1000RR.net
post #1 of 16 Old 03-11-2012, 03:37 AM Thread Starter
twistingthrottlenz
twistingthrottlenz's Avatar
I was searching around for a how-to guide for a fan switch for the 06 model but I couldn't find anything specific, so I decided to make one myself.
This switch setup lets you dictate when the fan comes on (switch position ON), or leave it up to the bike as per normal via thermostat reading (switch position OFF).
Sorry for quality of pics - taken with my Blackberry. You can click on the thumbnail to enlarge.
1. Take off your left side fairing
(I'll assume you know how to so this, so no pics)
2. Next to the fusebox you'll find a box containing a selection of relays.
Remove the rubber sleeve from the box.
3. Press in the brown clips and pull out the brown plastic casing
You want the left hand relay in this picture, which is the fan relay.
4. Flip the case over to reveal the wires.
The only wire you'll want is the grey-blue wire, which provides ground to the relay, as highlighted.
5. Wire up your switch.
This is the switch I bought (DPST rocker type switch) which meets my criteria: low mass profile, able to see which side is on, and locking nut on the reverse end.
This is how I wired up the switch. Soldered two wires - one to ground the switch (end post) and one to go to the relay (middle post, same row). Then covered solders with heatshrink and insulation tape, and heatshrink on the whole end of the switch so provide some protection from the elements. This picture shows my practice run with wiring...actually I had to buy a new switch because I stuffed this one up.
6. Choose a mounting point.
I chose to mount in the case where the exhaust valve servo lives, by the lock to release the rear seat. I had to relocate the servo to directly under the rear seat, but am gonna get the servo eliminator soon so this is temporary.
To remove the casing you need to remove the annoying screw thingee here:
And a nut here:
Then just remove the locking cable from the bracket that holds the rear seat on:
I used the locking nut from the switch to mark out the hole I needed to drill...you'll note that it's off-center with the lock but the casing slopes just after half way down and I wanted a flush fit for the switch.
As you can see I drilled heaps of little holes as I didnt have a drill bit big enough, and I filed them out to make one big hole.
7. Run the wires and reassemble the servo case
I ran the wires through the same hole the locking cable goes through, then grounded the ground wire to the frame and ran the "relay" wire under the gas tank to the relay.
I stripped the end of the wire, tinned it, and shoved it into the same socket that the grey-blue wire goes into.
8. Test, reassemble fairings, then done
Here is where i put the servo (temporarily under the rear seat, by the left hand vent thing)
And this is the finished result:
I can easily reach for and flip the switch while riding. If you have any questions please let me know
Last edited by twistingthrottlenz; 03-12-2012 at 07:37 PM. Reason: made clearer and fixed some grammatical errors
twistingthrottlenz is offline
post #2 of 16 Old 03-11-2012, 01:23 PM
cbrvik
Thanks for the write up!! I will be getting this done on my 06 before the Texas summer kicks in.
cbrvik is offline
post #3 of 16 Old 03-11-2012, 02:23 PM Thread Starter
twistingthrottlenz
No probs
I tested it on my commute to work today, works better than expected.
Usually when I hit traffic lights after about 20km into my run the bike climbs quickly to 104 degrees celcius, then the fan comes on.
Today the bike didn't even hit 90 degrees celcius.
Side note -I really like the sound the fan makes...kinda like a jetliner winding up
post #4 of 16 Old 03-11-2012, 09:51 PM
07 Fireblade
nice DIY, i just noticed that we have the same battery
07 Fireblade is offline
post #5 of 16 Old 03-12-2012, 04:16 PM
MrDude_1
Huge Member
MrDude_1's Avatar
nice writeup.
btw, if you didnt tin the end of the wire after you stripped it, it may corrode over time....
MrDude_1 is offline
post #6 of 16 Old 03-12-2012, 07:37 PM Thread Starter
twistingthrottlenz
Thanks man
I did apply some solder to the end - will edit writeup.
post #7 of 16 Old 03-20-2012, 07:16 AM
06cbr1000rrNY
06cbr1000rrNY's Avatar
awesome I will have to tackle this....hopefully this weekend...great write up
06cbr1000rrNY is offline
post #8 of 16 Old 03-24-2012, 04:03 PM
2003csl
nice write up
2003csl is offline
post #9 of 16 Old 07-08-2012, 04:23 PM
Red Dog
Red Dog's Avatar
Sweet! Thanks for the how to..
Sent from my iPad using MO Free
Shhh!!! Can you hear that?
Red Dog is offline
post #10 of 16 Old 07-23-2012, 01:03 PM
DJuanHouston
Spin Doctor
DJuanHouston's Avatar
Now figure out how I can run a second fan cause the road is 120+ now and when stopped at a light it doesnt matter when my fan came on it still hits 230F
Akra Evo, BMC Race, pair, Flapper, Harris rearsets /w Gilles GP shift, Elka 3rear, speedoH 520 -1 +2 and some stickers ;-)
DJuanHouston is offline
Human Verification
