How hard is it to replace the throttle cables : Honda CBR 1000RR Motorcycle Forums: 1000RR.net
Go Back   Honda CBR1000 Forum : 1000RR.net > CBR1000RR Modifications > 1000RR Mods and Upgrades > Modifications & Upgrades 06-07
Old 09-29-2012, 02:58 AM   #1
sovain's Avatar
Any tips or a DIY would be awesome I have a 07
sovain is offline   Reply With Quote
Old 09-29-2012, 06:50 AM   #2
GligorovDimce's Avatar
Press search button, there was diy for that on this forum.
2008 Honda CBR 1000RR
Silver-Black
Arrow GP 2
Two Brothers Juice Box
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
Hot bodies smoked windscreen
Michelin Pilot Power tires
Shogun Frame Sliders
RR Swingarm Spools
12 V Outlet
Old 09-29-2012, 09:42 AM   #3
TexasTraffic's Avatar
Yes... and it's a pain in the azz
Getting to the connections at the throttle bodies it a bit involved.
2012 CBR1000rr
http://www.1000rr.net/forums/image.php?type=sigpic&userid=32823&dateline=133199  7534
TexasTraffic is online now   Reply With Quote
Old 09-29-2012, 02:50 PM   #4
I know, i readed that DIY and i said this is not for me.
If i would have to do that,will go to a bike shop.
Silver-Black
Arrow GP 2
R6 Throttle Tube
Flapper Mod.
Dual Fan Switch Mod
K&N Air Filter
RR Swingarm Spools
12 V Outlet
Old 11-11-2012, 07:41 PM   #5
mutilate718's Avatar
i had the shop install the hrc throttle kit i didnt want to deal with the trouble... i do most of the work on my bike aswell
''FASTER THAN A SPEEDING TICKET''
cbr1k 07 black, yosh slip-on, Kn fiters, Pclll, goodridge braided lines all around, 2ct's
mutilate718 is offline   Reply With Quote
Old 11-11-2012, 09:35 PM   #6
I just replaced mine about a week ago. The shop charge me 1.5 hrs of labor= $129
just getting the cables off and on the throttle tube was APITA. i was just replacing the throtle grip/tube due to a broken handle bar. i was soo frustrated i was cursing in so many languages!! I was working on the bike outside and it was cold which added to the frustration on hooking up the cables back on the grooves on the tube.
After the experience replacing the broken handle bar where i had to replace my throttle tube and deal w/ the throttle cables. I gladly paid the $I29. I actually felt bad for the guy that did it cuz he had to do them.
I read the 2 DIY writes ups/ both w/ great pictures, tips, instructions. And i also have the service manual. It doesnt seem that hard, ITS JUST PATIENCE W/ THE CABLES because there seems to be no slack for the cables to be hooked where they are suposed to be...For me the deciding factor to taking it to the shop was the weather and shop rate.
If i had a garage i could have taken my time and learn more about the bike while doing them and feel good after finishing the job! But no regrets hooking up the cables really is APITA!!
cbr100rr is offline   Reply With Quote
Old 11-11-2012, 09:50 PM   #7
Goose
It's not that hard.
Remove tank cover and airbox, all exposed.
Remove old, replace with new, done.
Set aside 4 hours. If you know what you're doing it'd take about 1.5. But dont rush it.
Make sure to adjust it at the throttle body cam pretty tight, and final adjustment at the bar.
Download an 04-05 manual if not feeling confident.
Shamizzle is online now   Reply With Quote
Old 11-12-2012, 12:21 AM   #8
just did this on my 06 sv650...its a pain. most likely you will get the old ones out but they new ones are a pain to put in xuz its so tight
Old 01-19-2013, 06:20 AM   #9
sovain's Avatar
Originally Posted by Shamizzle View Post
It's not that hard.
Do I have to remove the gas tank its self?
Old 01-19-2013, 08:27 AM   #10
Lifetime Premium
blr3015's Avatar
No the tank will tilt back. I use a piece of wood to let it rest on. Replacing the cables isn't really hard but can get time consuming. The difficult part is the bottom cable. It is like you are threading a sewing needle with welding gloves on. If you have anything such as surgical hemostats those will help or long needle nose pliers. Anything that is long and narrow that can hold the cable will work. Do a search, not just here, so you get an idea. Youtube has some good videos. Once you get them replaced turn your handle bars to see if it is binding anywhere.
2006 Red 1000rr
2006 Black 1000rr (CRASHED)
Originally Posted by Cmac View Post
Man Law: Thou must use the search feature when appropriate so thou does not get flamed.
To better understand the coarse, belt-sander nature of asphalt at speed, simply apply an unprotected hand to the freeway’s surface the next time you’re the passenger in a car. If you’re unwilling to do this, how do you justify riding a motorcycle without protection?
blr3015 is online now   Reply With Quote
