Hello folks, these are some parts left over from when I rebuilt my 2008. Any damage I tried to capture in the pictures as best as possible, if more imagery is required just let me know.
Lowers in Winning Red, some scratches down to the primer that could probably be filled in with a touch up pen. One lower has two borked tabs for the ram air tube. The tube ends up a bit loose if you try and turn it as you would to unclip it from the tab but still remains in place once everything else is snapped together.
I could try polishing out the lighter marks that aren't down to primer. I'll try and get better pictures over the weekend.
$225 shipped for both or best offer.
Complete lock set. The fuel door has been ground a bit and the key is bent but still works. The code is still there to cut a new key. $75 shipped or best offer.
