Not sure what they mean by the "Preload:10" for the rear? If it is clicks from hard, isn't that full soft as I thought there are only 10 clicks in total?
Set your sag and have someone who works on suspensions set it gor you. It's worth the 30-40$ to do it right the first time. Most people that answer these questions don't have a clue.. Most, not all just for the record
quick question on the showa bpf, when adjusting preload on the front shock. how do i know i have reached max preload? i tried spinning it i heard the clicks but it doesnt have a physical stop as the comp and rebound do. how do i know when it is full stiff or full soft?
There is a stop point when cranking the 2012 front preload to full hard, in other words crank the allen key pre-load towards full hard and it should hit a stop point when you've reached the max setting (do not turn it too hard) :thumbsup:
