12-03-2012, 02:15 PM
#1
Admin
Used Parts Thread 08+ cbr 1000
Just to make things a bit easier, im going to go ahead and keep a current used parts section here. this is the 08+ parts thread. if you are not sure if something i have will fit your bike, just ask. no prices below include shipping. if you bundle, you save on shipping.
black oem upper-mint-$150
black oem lh mid-mint-$225
black oem rh mid-mint-$225
black oem tail-mint-$95
black oem front fender-mint-$95
rh mirror-mint-$120
lh mirror-mint-$120
headlight assy-mint-$250
oem black painted lower-mint-$200
09 oem undertail-mint-$50
2010 oem undertail -mint-$50
rear passenger peg set-$50
oem air filter-500 miles on it-$20
ten kate sbk tail for stock subframe-new-$160
(2) swingarm/shock linkages-$25 each
complete triple trees-$75 each
oem shock-$25
oem harness setup up for track use-$100
(2) velocity stacks-$25 per set
upperstay-$40
oem damper/mount-$25
(2) regulator/rectifier-$25 each
exhaust servo-$10
ecu-$150
f/r axle set-$20
sprocket cover-$10
oem slipper-$100
HRC throttle housing-$15
(2) oem brak master cylinders with reservoir/stay-$50 each
(2)fuel pump-$25 each
sharkskinz race lower-$100
(3)oem brake/clutch lever sets-$35 each
(2) lh handlebar light switch-$25
rear caliper set with hel brakeline and rear master-$50
hel front brake lines-$25
rear wheel-$150
side mount exhaust bracket-$10
(2) brocks full ti exhaust with sato gp cans-$750 each
clutch perch-$20
pazzo short black clutch lever-scuff on the ball of the lever-$25
(2) front seats-$50 each
(2)rear seats-$50
shoot me a pm, or call me to order or check shipping costs.
