ECU map set selector switch - Honda CBR1000 Forum : 1000RR.net
post #1 of 17 Old 04-20-2018, 12:40 AM Thread Starter
PuffTheMagic
PuffTheMagic's Avatar
I am trying to figure out which pin on the ECU is responsible for selecting between the two different map sets. Based on the schematic from this '08 HRC manual (http://www.firebladezone.com/docs/08CBR1000-HRC.pdf) it seems like the mode selector is pin24 on the gray connector. This pin is not connector to anything on the non-HRC schematic. Can anyone with access to a newer HRC manual see if you can confirm the mode switch pin, or better yet, post up a schematic? Thanks.
2012 CBR1000RR (track) - MCU Innovations ECU flash, Hotbodies MGP Growler slip-on, Armour Bodies Bodywork, R6 throttle tube, Tightails Aluminum Subframe & Upperstay, Shorai lithium battery, Fast Frank front & rear captive wheel spaces, Fast Frank captive rear caliper bracket, flapper mod, pair mod, nicky mod, GP shift, Galfer GP brake lines, RaceTech springs, 600rr rear link mod
2002 XR100R (pitbike/minimoto)
2002 SV650 (track)
1996 KDX220 (dirt)
PuffTheMagic is offline
post #2 of 17 Old 04-20-2018, 01:12 AM
RC45
Lifetime Premium
RC45's Avatar
For 2017 SP2 HRC ECU pin 29 grey connector is FI\IGN Mode switch which is mapped to left of Hazard Switch when using stock left bar switch cluster or Map Selector on HRC left bar switch cluster.
Pin 29 on the street SP2 ECU grey connector is open.
The Good RS250R NF5 The Bad TZ250 2KM The Ugly LS7 C5Z07 Gone but not forgotten RC45 Delivered US SP2 #65
SP2 Delivery Thread < - Delivery Thread
RC45's SP2 Trackday Bike Build Thread <- Build Thread
RC45's US vs UK ETV Tables Dyno <- Dyno Page
PAIR Mod HRC Style <- HRC PAIR Page
Myths & Mysteries of the SP2 ECU Thread <- ECU Thread
RC45 is offline
post #3 of 17 Old 04-20-2018, 01:28 AM Thread Starter
PuffTheMagic
Thanks. Pin 29 is in use by something else on the 08-12 havent looked at newer models. On that 08 HRC schematic the ECU pin is called "MOD SW" but is also connect to the hazard switch. I wont be able to test this until my order from cycleterminal arrives.
2002 SV650 (track)
1996 KDX220 (dirt)
post #4 of 17 Old 04-20-2018, 01:40 AM
RC45
Lifetime Premium
RC45's Avatar
In this discovery process I should imagine the actual pin across model years is not important, just that the same pin being used for an HRC specific function is not being used for anything on the stock ECU is probably more important.
RC45 is offline
post #5 of 17 Old 04-20-2018, 01:48 AM Thread Starter
PuffTheMagic
I think the pin is going to be consistent on all the standard Keihin (non-HRC) ecus. All that you need to do is connect the pin to ground and the second set of maps kick in after the next gear change.
EDIT: Pin 24 on the 2006 HRC schematic goes to an empty connector.
2002 SV650 (track)
1996 KDX220 (dirt)
post #6 of 17 Old 04-20-2018, 02:10 AM
RC45
Lifetime Premium
RC45's Avatar
Pin 24 for 2017+ is a common ground on both stock and HRC grey plug.
RC45 is offline
post #7 of 17 Old 04-20-2018, 02:11 AM Thread Starter
PuffTheMagic
I think it fair to say that nothing on the 2017 is going to be similar.
2002 SV650 (track)
1996 KDX220 (dirt)
post #8 of 17 Old 04-20-2018, 02:33 AM
RC45
Lifetime Premium
RC45's Avatar
I don't think that is the key take-away here - I would not be so concerned with finding literal matching pin outs across years.
That thought process may limit your discovery. I might focus on common use and vacant pin outs across stock vs HRC ECU for the same years to narrow down on functionality discovery.
But that's just me.
RC45 is offline
post #9 of 17 Old 04-20-2018, 02:41 AM Thread Starter
PuffTheMagic
Maybe its just late and I need to go to bed, but that is what I am doing. The 08-14 schematic only has a few empty pins on the gray ecu connector (which is sensors/inputs) and pin 24 is one of the empty ones. So far the 07 and 08 HRC kits use pin 24 for the mode switch so it seems like that is the best bet to start testing for me to get mode switching working on my stock 2012 ECU.
2002 SV650 (track)
1996 KDX220 (dirt)
post #10 of 17 Old 04-23-2018, 12:19 PM Thread Starter
PuffTheMagic
My ECU connector came and it has way more pins than I will need for my bench harness. I should be able to use one of these pins to add the map switch to my factory harness.
Sent from my LGLS992 using Tapatalk
2002 SV650 (track)
1996 KDX220 (dirt)
