Calling all Woolich flashed 2017+ folks... - Honda CBR1000 Forum : 1000RR.net
post #1 of 88 Old 11-20-2019, 05:11 PM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
If you have a 2017+ base, ABS, SP or SP2 that has been Woolich flashed please check into this thread.
Please note in your reply the model of bike, if you put miles on the stock ECU before the flash or if you bought the bike with the flash so you never rode it with stock ECU.
Also note if you are street only or if you ever took the bike to the track - either before or after the Woolich flash.
I am particularly interested in any differences you may have noted between Torque Management intervention response before the flash and after the flash.
The Good RS250R NF5 The Bad TZ250 2KM The Ugly LS7 C5Z07 Gone but not forgotten RC45 Delivered US SP2 #65
SP2 Delivery Thread < - Delivery Thread
RC45's SP2 Trackday Bike Build Thread <- Build Thread
RC45's US vs UK ETV Tables Dyno <- Dyno Page
PAIR Mod HRC Style <- HRC PAIR Page
Myths & Mysteries of the SP2 ECU Thread <- ECU Thread
RC45 is offline
post #2 of 88 Old 11-20-2019, 06:23 PM
Shinji43
Lifetime Premium
Shinji43's Avatar
Garage
2017 SP
Put approx 1000mi before flashing
Street use only as of now
Only issue I’ve seen in relation to the torque management, which I was meaning to ask about, is I’ve noticed anytime I trigger the anti-wheelie, I’m unable to change modes until I turn the bike off/on. The intended mode change will just stay flashing instead of actually changing when coming off throttle. I’m able to change modes normally any other time, but just notice it happening once anti-wheelie activates. Only modification to the tables I made was to have T1 act like T0 (to not need to change every start cycle). Once I noticed it happening I restored the original values and it still does it.
2003 CBR 954RR (Track Only)
2007 CBR 1000RR Repsol Edition
2017 CBR 1000RR SP #093
Shinji43 is offline
post #3 of 88 Old 11-20-2019, 07:01 PM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
Originally Posted by Shinji43 View Post
2017 SP
Only issue Iíve seen in relation to the torque management, which I was meaning to ask about, is Iíve noticed anytime I trigger the anti-wheelie, Iím unable to change modes until I turn the bike off/on. The intended mode change will just stay flashing instead of actually changing when coming off throttle. Iím able to change modes normally any other time, but just notice it happening once anti-wheelie activates. Only modification to the tables I made was to have T1 act like T0 (to not need to change every start cycle). Once I noticed it happening I restored the original values and it still does it.
Does the TC light flicker during wheelie intervention and does the bike still intervene on future wheelies before you turn the bike off/on again?
Do you recall if the bike behaved as above when it was stock?
And in the current state, what happens if you set the dash to P1 T9 and you try spin the rear wheel while under way? Does the Torque Management intervene?
RC45 is offline
post #4 of 88 Old 11-20-2019, 07:10 PM
Shinji43
Lifetime Premium
Shinji43's Avatar
Garage
No, I've never noticed the TC light coming on anytime the wheelie intervention kicks in, but it will continue to intervene during the same power cycle. I couldn't say if it acted like that prior to the flash since I didn't really try to get on it enough to trigger it before the flash.
I'll have to try setting the modes that way and see what happens, so more to follow on that.
Shinji43 is offline
post #5 of 88 Old 11-20-2019, 07:15 PM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
Thanks.
If I manage to secure an unflashed SP ECU I might send it out to various SP Woolich Flashed folks for testing back to back against their Woolich Flashed ECUs.
I tried to buy a new one and it looks like Honda have already discontinued the part number.
I managed to buy a new SP2 ECU that we are using for testing.
RC45 is offline
post #6 of 88 Old 11-20-2019, 08:03 PM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
OK - we have confirmed that weird mode flashing thing requiring the bike be shutoff, appears to be caused by the Woolich flash. Stock SP2 ECU does not do that.
Maybe @Bevo can be our stock SP validation of whether stock SP can switch modes without shutting off the bike.
RC45 is offline
post #7 of 88 Old 11-21-2019, 07:56 AM
Bevo
Hook 'em!
Bevo's Avatar
Garage
Never had any issue with this bike except for the recalled fuel cap. Switching modes is seamless whether on the fly or stopped.
25th Anniversary Edition CBR1000S1 Hurricane
Bevo is offline
post #8 of 88 Old 11-21-2019, 11:32 AM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
That's pretty much what I thought - I recalled making on the fly mode changes on the stock SP2 ECU, and your confirmation of the same behavior on the stock SP ECU is leading me to suspect most of the TC issues with the SC77 are related to flashed ECUs.
We are having some final testing done later today - I hope my suspicion is not correct
RC45 is offline
post #9 of 88 Old 11-21-2019, 02:07 PM
Shinji43
Lifetime Premium
Shinji43's Avatar
Garage
Yea, does seem to be the culprit so far. When doing a bit of research, I did notice in the service manual the note about mode changes cannot be made while torque management is active. So I'm wondering if once its triggered by an event, on some level it is still considered active, thus not allowing mode changes till you power cycle the bike. Let me know if you want me to try any other tests or make any tweaks to any of the maps/tables and I'll write it into my ECU to see how/if it affects anything.
Shinji43 is offline
post #10 of 88 Old 11-21-2019, 02:41 PM
Maximus7
Lifetime Premium
Maximus7's Avatar
Not sure if this is related to your research here but I noticed pre-flash I had to come to complete stop to change user modes if it involved EB change. Post flash itís all on the fly, Iíve a Commuting mode map & a canyon mode map with a change in EB among others
Maximus7 is offline
