Replace piston rings - Honda CBR1000 Forum : 1000RR.net
post #1 of 6 Old 02-24-2019, 06:07 PM Thread Starter
MaxHitZ
MaxHitZ's Avatar
quick question, is it possible to do the rings without splitting the cases (disregard manual)
MaxHitZ is offline
post #2 of 6 Old 02-27-2019, 05:33 PM
swoopp
swoopp's Avatar
Not 100% sure...but, I'm going to say NO. You are going to have to pull the engine, remove the cylinder head and the oil pan. Cracking the case isn't going to be too much more work.
BLAH BLAH BLAH
swoopp is offline
post #3 of 6 Old 03-05-2019, 08:53 PM Thread Starter
MaxHitZ
MaxHitZ's Avatar
guess a question to the opposing side, can u do rod end bearings without removeing the head?
MaxHitZ is offline
post #4 of 6 Old 05-15-2019, 08:58 PM
Alan Wilson
Sure can. Remove the oil pan and pump, then use a wobbly ratchet extension to reach the connecting rod bolts to get the pistons out.
Alan Wilson is offline
post #5 of 6 Old 05-15-2019, 09:01 PM
Alan Wilson
No way to get con rods/piston out without removing the head.
post #6 of 6 Old 05-15-2019, 09:14 PM Thread Starter
MaxHitZ
MaxHitZ's Avatar
Not talking about rods/pistons in relation to post #3 only end caps and bearings
Alan, quite right however ended up splitting the case anyway, lucky, couple crank bearing caps knackered also
MaxHitZ is offline
Similar Threads
Survey: new piston rings 08/09 1000rr mnguyen84 1000RR General Discussion 25 03-06-2013 11:31 AM
To Replace or Not to Replace akdoc 1000RR Brakes 14 10-06-2012 10:09 PM
Do you replace you caliper mounting bolts when you replace your tire? King Of Beers 1000RR General Discussion 3 05-09-2010 08:26 PM
HRC Piston Rings question m48 Modifications & Upgrades 06-07 0 12-22-2009 02:35 AM
Can you replace 'just the rings' in an 08+? djhartm 1000RR General Discussion 12 06-29-2009 07:56 AM
