Bogging at high revs, need help - Honda CBR1000 Forum : 1000RR.net
post #1 of 8 Old 05-15-2019, 08:39 PM Thread Starter
Wdeez6
Unhappy Bogging at high revs, need help
Hello everyone,
My 04 cbr1k has been bogging out around 7-8k and came to the conclusion of a fuel hose kink. I ended up buying a oem fuel line and i installed it and it seems it helped out and it went up to 10k rpms and will bog out and it did this for one day and then the very next day i went to start it and warm up and started to head home and the same thing. it drives fine untill it hits around 6-8k rpms and bogs out. Can anyone send me pictures of where i need to position the fuel line? It feels like the oem one i bought is just a half inch too short and its stretching or kinking when it makes that 180 degree turn towards the fuel rail. if someone can please send pics or anything so i know im routing the fuel line the right way. Thank you and i am about to set the bike on fire and go purchase another one.
Wdeez6 is offline
post #2 of 8 Old 05-15-2019, 09:05 PM
Liquid_IQ
Liquid_IQ's Avatar
Could be a weak/clogged fuel pump.
Liquid_IQ is offline
post #3 of 8 Old 05-15-2019, 09:12 PM
Alan Wilson
Same thought here, check the strainer and pressure test the fuel pump
Alan Wilson is offline
post #4 of 8 Old 05-15-2019, 09:12 PM Thread Starter
Wdeez6
I’ve taken fuel pump out and taken the filter/sponge thingy and cleaned it out.
Wdeez6 is offline
post #5 of 8 Old 05-15-2019, 09:21 PM
Alan Wilson
Unfortunate. That leaves fuel pressure regulator, secondary injectors, airflow, or weak spark/plugs to check.
post #6 of 8 Old 05-15-2019, 09:23 PM Thread Starter
Wdeez6
Looked for the fuel regulator, I can’t find that in the manual, I’ve found the map sensor where the primary injectors are, is that what you are talking about?
Wdeez6 is offline
post #7 of 8 Old 05-15-2019, 09:38 PM
Alan Wilson
FPR is inside the tank attached to the pump assembly. Check that the secondary injectors are clean and flow well if the issue occurs above 1/4 throttle, it kinda sounds like they aren't opening up or there isn't enough pressure to feed properly. The fuel line will only really fit in there one way, just make sure it's positioned as well as you can get it when dropping the tank, and be sure all the hoses on the throttle body are in good shape.
post #8 of 8 Old 05-15-2019, 09:49 PM Thread Starter
Wdeez6
I’ll pull the secondary’s out and make sure there not clogged and I have to get a pressure gauge. Thanks I will get back to you
Wdeez6 is offline
Similar Threads
06 cbr1000rr revs at 3500. 06 blade 1000RR General Discussion 9 01-15-2013 05:32 PM
05 cbr600rr clicking sound with revs Truthalive7 1000RR General Discussion 4 08-30-2012 09:49 PM
Lumpy at low revs? Map needed? CBR Sam 1000RR Exhaust & Fuel Delivery 4 03-30-2010 02:17 PM
Installed PC V w/ IRC...Stuttering Issues in High Revs speednut 1000RR Exhaust & Fuel Delivery 25 10-25-2009 05:07 PM
HOW TO GET MORE REVS AND TOP END POWER 08 1000 ? livharder Modifications & Upgrades- 08-11 8 06-04-2008 05:31 AM
