High idle does not drop (2005) - Honda CBR1000 Forum : 1000RR.net
post #1 of 5 Old 05-19-2019, 06:10 AM Thread Starter
RpgCyco
I'm having an issue with the idle speed on my 05 track bike that I'm hoping someone can help me with.
On a cold start (e.g. after sitting overnight), the idle will start at around 2000 RPM which is normal for a cold start (my 06 does it too) but what isn't normal is that it does not drop down to 1200 after reaching ~35-40C. It actually rises gradually. By the time it hits 55C, the idle is around 2100-2200 and the fan is on!
Once the thermostat opens (the right hand side coolant pipes get hot around 80C) the idle will start to gradually drop. Once the temperature reaches 100C+, it drops to around 1400.
Curiously, if I leave the bike to sit for 20 minutes so the temp drops to around 75C, when I start the bike it idles perfectly and will continue to do so until cold again.
While it's idling too fast, I cannot get the idle to drop with the adjustment screw. I can get it to go even higher though, so the adjustment screw is connected and working.
The first thing I suspected was the vacuum hose from the intake flapper that I removed, but it seems OK. When I try removing the plug it idles even higher, so I believe the plug is OK. All other vacuum tubes at the throttle bodies are connected and appear to be undamaged.
Given that it appears related to coolant temp, I suspect there may be an issue with IAC thermal valve.
Any ideas of what to check/try would be greatly appreciated.
Cheers.
RpgCyco is offline
post #2 of 5 Old 06-09-2019, 10:38 AM
Fireblade61
I'm not dead yet.
Fireblade61's Avatar
mine was a malfunctioning enricher. I cleaned it and made sure the wiring wasn't screwy, and it started behaving again. Check for pinched vacuum lines also.
Leather up, rubber down
08 1000rr, +80,000 miles
Evolve GT #61 Int.
Fireblade61 is offline
post #3 of 5 Old 06-09-2019, 03:06 PM
Liquid_IQ
Liquid_IQ's Avatar
What the heck is an enricher?
Liquid_IQ is offline
post #4 of 5 Old 06-12-2019, 06:03 PM
Fireblade61
I'm not dead yet.
IACV
Evolve GT #61 Int.
post #5 of 5 Old 07-12-2019, 02:07 AM Thread Starter
RpgCyco
Thanks.
The older bikes (04-07) don't have an electronically controlled IACV, they've got a little cylinder filled with wax that coolant passes through, which heats and expands the wax which then operates a piston which closes the idle holes in the throttle bodies.
I suspect the one in the bike I purchased was ruined from sitting in some guy's garden in the weather for 5 years. Haha.
Anyway, I purchased a new part which I'll install when I next service the cooling system.
RpgCyco is offline
Similar Threads
Rough idle after tip over(loping idle?) Runeknight95 1000RR Exhaust & Fuel Delivery 9 07-10-2018 05:06 PM
Bike Does not Start/Fuel Pump Does not run msk Modifications & Upgrades- 12 3 02-05-2016 01:56 PM
High Idle - Bad IACV - Replaced - Good Idle speedslave 1000RR General Discussion 2 10-11-2013 05:31 AM
08 Fireblade does not burn one drop of oil jkim 1000RR Oil & Lubrication 38 07-16-2010 11:07 PM
Clutch not engaging bike will not idle with clutch in Tyler1000 1000RR General Discussion 1 06-15-2009 03:38 AM
