Looking for some guidance for oil leak - Honda CBR1000 Forum : 1000RR.net
post #1 of 6 Old 09-14-2019, 10:05 AM Thread Starter
Plante12
Plante12's Avatar
I have a 2016 with 6100 miles on it. Last ride I went on I came home and the next day I noticed a little pool of oil on the ground. Checked around the bike and noticed the oil smeared across the lower left side fairing.. checked oil level and it was low. So I added oil and the only place I can see it dripping from is obviously from the lowest part of the left side. My question is because I dont see it coming from elsewhere is it safe to assume it's just a gasket leaking or is there a point above that I cant see that I should be looking at? Before I take it to a shop I would like to gain some wisdom from you folks first to see if it's an easy fix. Last oil change was done around 4200 miles using honda oil 10w-40
Plante12 is offline
post #2 of 6 Old 09-14-2019, 10:06 AM Thread Starter
Plante12
Plante12's Avatar
Picture for reference
Plante12 is offline
post #3 of 6 Old 09-14-2019, 02:14 PM
hardcoremofonigg
FEB 2016 BOTM
hardcoremofonigg's Avatar
Location: Live in Durant,OK Born and raised in Houston,TX
I would check to make sure the oil filter is tight and the cap is in tight. Get down on the ground with a flash light and try to pin point the area.
06 Blue&Yellow1kRR
Power Commander 3
Jardine RT-1 Dual Outlet CF
Carrozzerias V-Tracks (Yellow)
Annitori RL Quickshift
Sticky Michelins 34F/36R
Galfer Steel Braided Lines
ProGrips SBK Black
Pearl Flash Yellow Sargent Seat
EK X Ring Chain
Yuasa YTZ10s
Balls Of Steel
Light Rider Mod(135lbs)
Bell Star Isle Of Man Helmet
2013 Daytona Charger #1052(cager) Blue Beast
hardcoremofonigg is offline
post #4 of 6 Old 09-14-2019, 11:00 PM
child_of_fire
child_of_fire's Avatar
this is the only bike ive owned that leaked from the filter when new. id check that first. park the bike and check it while running / reving if youi can...
child_of_fire is offline
post #5 of 6 Old 09-15-2019, 09:17 AM Thread Starter
Plante12
Plante12's Avatar
So I checked the oil filter and its dry no signs of a leak. The oil fill cap and drain bolt are both tight. I did notice that it only happens after the bike gets up to temp. It sat all night with no sign of leaking but when I started it up this morning to check it I noticed that the oil was collecting on that bolt again. Not a lot like it was dripping but definitely noticeable
Plante12 is offline
post #6 of 6 Old 09-15-2019, 11:43 AM Thread Starter
Plante12
Plante12's Avatar
Forgot to mention the pic I posted is upside down and on the left side as if I was sitting on the bike
Plante12 is offline
