2012 CBR 1000RR
Thread Tools |
The only performance mod on my '12 1000rr is a Yoshimura slip on. There is also a quickshifter but not sure if that affects anything as far as the ecu. I just want my bike to be running efficiently and I do not plan on racing or doing track days, it's just a weekend bike for pleasure as I'm a casual/conservative rider. I read I don't need to worry about a fuel management device since I only have a slip on. Is an ECU flash recommended or any other type of professional tune for my style of riding?
2012 CBR 1000RR
ATLANTA, GA.
Sponsored Links | |||
Mike- Short answer: You "need" the flash about the same as you "needed" the Yosh and Quickshifter.
Longer answer: Every bike comes from the factory with compromises built in. Most of the compromises that are programmed into the ECU are governmental compliance requirements levied upon the manufacturer. DOT and EPA regulations assume that the purchaser does not have the means to remove the restrictions. I'm not a lawyer, but I suspect that some modifications could make the vehicle technically illegal in certain states/jurisdictions due to noise or other pollutants that the restrictions were designed to tame- noise being the most of it, I suspect. So Caveat Emptor is a general disclaimer.
I've heard nothing but good things from those that have done ECU flashing with exception of @LDH who reported a customer service problem with a certain vendor who did his ZX-10 before he purchased it.
-06 CBR1000RR- (Track/Street)(Build Thread) (Version 2.0)
-13 CBR250RA Hers SOLD
-02 CBR600F4i (Track/Street) (mine)
ZG Dbl Bbl, Galfer SS Lines, PC3r, Muzzy s/o, K&N air filter, NRC stator cover, ShiftMinder(WTF?), Fireblade brakes, Rearsets, Factory Pro Shift Kit, Ohlins-Racetech&Showa custom Suspension
-92 CB750 (Hers)
-06 CRF230F (mine, sold)
-97 XR100
-07 CRF50F (son's), PW50 (sold)
-13 CRF110F -01 XR50 (Daughter's)
-06 TT-R125 (Mine)
Because 12,000 RPM makes me feel better
2012 CBR 1000RR
Originally Posted by Jaybird180
View Post
2012 CBR 1000RR
ATLANTA, GA.
Consensus seems to be you can run a slipon with stock ECU. OR you can run stock exhaust with Zbomb on stock ECU. IMO Zbomb is a better mod than a slip on (if you ever go above 10500 RPM WOT).
ECU flash is $190 and you get the benefits of Zbomb without installing one. You also get benefit of the slip on top end power and 8 pound savings. So I think it is safe to say ECU flash makes Zbomb pretty much obsolete and ECU flash is one of the best bang for the buck mods.
Not bad numbers
2017CBR1000RR
To My Beloved Father RIP, Love You Dad
I just ordered the ECU flash, and I will be sending my ECU tomorrow. My question is, will the reflash be able to remove the "on-off switch" nature of my throttle at "1%" throttle? It's a real problem for me in low speed corners.
2005 Repsol- Wrecked
2008 1000RR- Stolen
2012 CBR1000RR-
Power Commander V
Yoshimura R-77 full exhaust
BMC Race Air Filter
Lee's Cycle Velocity Stacks
Dyno Tuned by Lee's Cycle
Diamond Racing Products Rearsets
eBay Levers
R6 Throttle Tube
168.9HP/80LB./FT.
Your vendor would be best to answer but there's an ECU feature called "in-gear idle speed" that can do wonders with the low range area just getting back on the gas. I suspect a re-tune (per your sig) can also help.
-92 CB750 (Hers)
-97 XR100
-06 TT-R125 (Mine)
If ECU flash doesn't help, adjusting chain tension might reduce on-off lash. Not sure if it is best to coast through with clutch in or putter through in 1st?
I have heard that you can pull clutch in and rev up the motor to get some centrifugal force assistance but it doesnt seem to help much.
I think coasting through the turn with the clutch is a riding error. The throttle should come on as soon as possible, meaning the steering action is completed and the bike is pointed in the intended direction and you're on-line. You can then begin to smoothly roll on the power, transferring the weight to the rear tire's larger contact patch. Can't do that with the clutch disengaged.
It never dawned on me that's what @BEUJAXXON was talking about. However, I have ridden bikes that have a distinctive on/off notchiness feel to them. I haven't felt it on my Fireblade but on my F4i I would sometimes have to roll on the throttle to take up chain slack first then I can begin the throttle roll. That chain slack took up a little extra time and attention. It stopped doing it, so I think it may have been a maintenance issue.
-92 CB750 (Hers)
-97 XR100
-06 TT-R125 (Mine)
Yes I thought he was talking about taking a 90 degree right hander on the street at a stop sign etc, often covered in sand and pebbles. Our bikes have so much power on tap in 1st gear that if you keep the clutch fully engaged the tiniest throttle movement will snap the power on, made worse by drive lash. Now that I re-read it looks like he is talking about on track? I agree that on track coasting with clutch in is incorrect form and probably never slow enough to be necessary.
Sponsored Links | |
Thread Tools | |
Posting Rules | |
