ECU Flash with Quick Shifter $415.00 !!!!! - Honda CBR1000 Forum : 1000RR.net
post #1 of 4 Old 06-03-2018, 03:50 AM Thread Starter
Danos Performance
Vendor
Danos Performance's Avatar
Dano's Performance now offers ECU Flashing for the 2008-16 Honda CBR1000RR models. This service is only available to our U.S. customers. Our ECU flash removes all the restrictions programmed into the ECU from the factory. These restrictions greatly hinder engine performance and throttle response. We will optimize both the ignition and the fuel curve which will unleash horsepower from your engine.
Optimize fuel curves across all gear ( same as a Power Commander)
Dano's Performance now offers ECU Flashing for the 2008-16 Honda CBR1000RR models. This service is only available to our U.S. customers. Our ECU flash removes all the restrictions programmed into the ECU from the factory. These restrictions greatly hinder engine performance and throttle response. We will optimize both the ignition and the fuel curve which will unleash horsepower from your engine.Here is a list of features that are available for these models.
Optimize ignition curves across all gears (remove RPM & throttle based ignition restrictions)
Raise RPM limiter
Adjust idle speed
Adjust in gear idle speed
Disable pair valve
Disable steering damper
Disable O2 sensor
Disable exhaust valve
Reset radiator fan turn on/off temperature (205 / 195 )
Typically 3 yards (9 feet) can be gained per gear shift by using our Quick Shifter. This unit allows full or part throttle up-shifts without the use of a clutch. Microcontroller based design utilizing our own custom firmware which means this is cutting edge technology. This is a stand-alone unit in which no computer is necessary to operate it. Fully adjustable delay range of 55-70 milliseconds can be done in 5 millisecond increments via a 4 position rotary switch. We offer both pull and push type switch configurations for standard or reverse (GP) shift patterns.
All this for only $415.00 !!!
Please see our website at: http://www.danosperformance.com/Honda%20ECU%20Flash.htm
Danos Performance is offline
post #2 of 4 Old 06-16-2018, 08:18 PM
Liquid_IQ
Liquid_IQ's Avatar
What kind of turnaround time are we looking at for the ECU flash? Thanks.
Liquid_IQ is offline
post #3 of 4 Old 06-16-2018, 08:28 PM Thread Starter
Danos Performance
Vendor
The day we receive your ECU we will give you a call and go over the ECU flash features together with you then the very next day we will ship your ECU back to you via Priority mail.Delivery time for Priority mail is 2-3 days. Thanks Dan
post #4 of 4 Old 05-21-2019, 03:52 PM Thread Starter
Danos Performance
Vendor
This also includes the 2006-07 models. Thanks Dan
