RC45's SP2 Track Bike Build - Page 27 - Honda CBR1000 Forum : 1000RR.net
post #261 of 616 Old 06-24-2018, 03:06 AM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
Here you go - By the book PAIR & EVAP delete & catch can install.
After hearing horror stories of snapped bolts trying to install block off plates & seeing folks jerry-rig catch cans, I decided to follow the book and just do it HRC style
Did make 1 change though. I did not keep the charcoal EVAP which is still required even on race bikes in some jurisdictions. I just have the 2 outlets on the catch can feed each other.
The catch can vents to the atmosphere via the air box by pass tube.
The Good RS250R NF5 The Bad TZ250 2KM The Ugly LS7 C5Z07 Gone but not forgotten RC45 Delivered US SP2 #65
SP2 Delivery Thread < - Delivery Thread
RC45's SP2 Trackday Bike Build Thread <- Build Thread
RC45's US vs UK ETV Tables Dyno <- Dyno Page
PAIR Mod HRC Style <- HRC PAIR Page
Myths & Mysteries of the SP2 ECU Thread <- ECU Thread
RC45 is offline
post #262 of 616 Old 06-24-2018, 02:11 PM
Jaybird180
Lifetime Premium
Jaybird180's Avatar
Garage
No you didnít pay good money for HRC worm clamps! See now you done gone too far when perfectly good clamps can be found in bulk at a multitude of stores!!!
Is this disease treatable?!??? LoL
-06 CBR1000RR- (Track/Street)(Build Thread) (Version 2.0)
-13 CBR250RA Hers SOLD
-02 CBR600F4i (Track/Street) (mine)
ZG Dbl Bbl, Galfer SS Lines, PC3r, Muzzy s/o, K&N air filter, NRC stator cover, ShiftMinder(WTF?), Fireblade brakes, Rearsets, Factory Pro Shift Kit, Ohlins-Racetech&Showa custom Suspension
-92 CB750 (Hers)
-06 CRF230F (mine, sold)
-97 XR100
-07 CRF50F (son's), PW50 (sold)
-13 CRF110F -01 XR50 (Daughter's)
-06 TT-R125 (Mine)
Because 12,000 RPM makes me feel better
Jaybird180 is offline
post #263 of 616 Old 06-24-2018, 02:54 PM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
It says right there in the book, Clamps (Racing Kit) - so they must be special in some way ....
Actually, anything "normal" is usually just a regular Honda part number cheaply available via Partzilla. But I must say I do like using good quality galvanized hose clamps. I have always preferred the Honda bulk clamps to non-name bulk clamps.
When I swap the radiator I will replace all the single use clamps with worm clamps. But I am currently working ont he subframe.
RC45 is offline
post #264 of 616 Old 06-24-2018, 11:28 PM
Jaybird180
Lifetime Premium
Jaybird180's Avatar
Garage
Well excuse me while I go figure out how to change my dirt bike to GP Shift.
-92 CB750 (Hers)
-97 XR100
-06 TT-R125 (Mine)
post #265 of 616 Old 06-25-2018, 03:42 AM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
Getting there. But a couple critical challenges to address.
For sttock ECU IMU location is pretty critical. IMU mounts to ABS pump, Wheel speed sensors pass through ABS modulator.
So why reinvent the wheel, use the ABS hardlines to position the ABS pump for IMU mounting
To remove ABS function I will just pull the ABS pump fuse.
Finding a neat way to store the unused harness connections is a challenge.
I may relocate the regulator/rectifier to the old charcoal canister location - will give me that excuse to buy the cool carbon mounting bracket.
Now to find an undertail panel to clean up the bottom of the tail piece.
RC45 is offline
post #266 of 616 Old 07-02-2018, 03:54 AM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
Bought on a whim. Hopefully it will fit.
HRC GP/WSB floating rear brake disk.
RC45 is offline
post #267 of 616 Old 07-18-2018, 11:41 PM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
Some more Titanium... Even though many stock pieces are already drilled and pretty light, there is still weight to be shaved.
520 drive chain and sprockets & Ti fastners shave another 1.5lbs
Not sure why these fastener are Ti other than it looks cool
RC45 is offline
post #268 of 616 Old 07-18-2018, 11:55 PM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
HRC Harness ready.
Stock harness comes out... 6.5lbs
HRC harness goes in... 5lbs
Stock switch cluster plugs cannibalized for button pod. HRC switch cluster will be used when the bike is in Endurance guise
HRC high throttle in the Throttle By Wire world is the equivalent of the quick turn throttle int he analog world - yet it has 3 more degrees of rotation, 68* vs 65* for the stock throttle.
HRC NL9 clutch cable - shorter is better, doesnt block the dash view
RC45 is offline
post #269 of 616 Old 07-19-2018, 12:03 AM Thread Starter
RC45
Lifetime Premium
RC45's Avatar
Some pictures of the overall general progress.
RC45 is offline
post #270 of 616 Old 07-19-2018, 07:55 AM
HMAN
Blue Devil
HMAN's Avatar
Garage
Bike porn!
HMAN is offline
