Wondering if it is a direct bolt on? Also does anyone know if you have to change the cluster wiring harness and ecu, or can you use everything from 2008
No you can't! We went over this in your other thread. If you feel like wasting your time and money go ahead and buy the 08 cover. You'll discover that it won't fitso you want to say i can put 08 alternator cover on 13 mine?
You're better off buying everything new. Headlights are different too. All the body panels are different except for maybe the front fender.so hard to get 12 left side parts. i hope headlights same with 08 or different?
I just put a 2012 motor into my 08. Same motor as the 2013 everything bolted up fine. I was able to use everything from my 08 only thing is the neutral position switch/ sensor was different so I have it doesn't tell me I'm in neutral. I have to put the kickstand up and have the clutch pulled in to start my bike now. I also switched out the speed sensorCan some confirm if it fits? I found one local and want to do the swap
Sent from my SM-G920V using Tapatalk
How easy is it to swap out the fairing too?I just put a 2012 motor into my 08. Same motor as the 2013 everything bolted up fine. I was able to use everything from my 08 only thing is the neutral position switch/ sensor was different so I have it doesn't tell me I'm in neutral. I have to put the kickstand up and have the clutch pulled in to start my bike now.
I didn't swap out to the 2012+ fairings. Figuring out how to take off my 08 plastics for the first time was a pain though. Putting them back on was easyHow easy is it to swap out the fairing too?
I used my 08 ecu and wiring harness. Only thing that doesn't work is my neutral position switch; they changed to a different one in 2012. I'm not 100% sure but I may be able to fix that by changing to the 2012 sub harness.Looking to do the same project. 2008 bike with a bad motor and I have a 2012 motor and harness to swap in. Does everything get carry over from the 08? Specifically ecu. I believe the 12 harness is different for the cluster and front harness. So I might need a new harness and 12 cluster. Just trying to get everything sorted before I dig in.
Not yet I need to order one. Just curious, what was wrong with your motor?Didnyou ever try the sub harness? I have a 2015 motor on its way and will be doing the swap
You could just go with a 2012+ wiring harness instead of the 08 harness like I did.Is there a harness to make the neutral switch work after you put a 12-15 engine on a 08-11?
