61 - 64 of 64 Posts
Yes. As the traction control has nothing to with it. Stock the bike is not going to spin the tire on the dyno unless its not strapped down properly or the tire is shot.
Setting T0 doesn't disable ABS, or Quickshifter (both are systems that are disabled is a wheel speed sensor is not sending a signal). T0 simply stops the bike from intervening if the rear wheel spins or the bike wheelies.
thats the point i was trying to make on post 51. the red cbr clearly had traction control lites and checkengine lites lit in the video.hopefully i didnt piss anyone off with my post. i was just pointing out what i observed
so am i correct in assuming you cant dyno the sc77 correctly by turning off the traction control to T0. that you have to use the flash to turn off the front wheel sensor so the ecu doesnt smurff the dyno run.
Vendor - The SC77 Specialist
Pretty much you are spot on. (y)
61 - 64 of 64 Posts
