1 - 3 of 3 Posts
Here we are… Another victim of started last riding season, I moved and didn’t start it in the winter, now I’m a new battery, new plugs, new fuse in the fuel pump, new stator and it still cranks and cranks. No fire. Any recommendations would be great! Thanks in advance.
Kevin Butler
USMC veteran
BOTM Moderator
When you turn the key from off to on, do you hear the pump prime? it should pumps for a few seconds and then stop.
If it doesn't, flick the engine-kill back / forth a few times.
if the pump doesn't prime, the first culprit to check is the engine-kill button. Easy & cheap to open it and clean it up.
Thanks Bosston! Fuel pump primes. I emptied the tank and put fresh fuel in too. I had to replace the fuse for the fuel pump but she does groan at me every time I turn it on.
1 - 3 of 3 Posts
