Greetings. I had a similar issue w/ my'07. Was pulling my hair out after bypassing the clutch & the side-stand safeties. Even replaced the kill switch & the relays while I was at it. My pump functioned while directly wired to the battery & all fuses in the fuse-box had continuity , I figured I was covering all bases... Not the case. The connectors were snapped in completely. But the pins had gotten sloppy from disconnecting & reconnecting so many times. More accurately from not releasing the connectors as they were meant to be ( ...w/out pulling on the wires to get the connectors apart / trying to hurry through my repairs ). All I had to do was push the wires back into the connectors completely. I thought my issue was when the bike warmed up as well from the intermittent priming. But it wasn't. In my haste I forgot to use that good ol' common sense. ... Not to say that youre in the same boat that I'm in.
Maybe your issue wont require following the brown/black & green wires backwards from the pump to the fuel cut-off relay ... To both safeties...& onward. Check the connections first, though. Hope this helps. Good luck, Brother.
