Hello,
I am re-assembling my 07 after getting a few things powder coated(rear sets, passenger pegs/exhaust heat-shield) and was wondering if someone would be able to post a few detailed pics of the stock exhaust heat shield on the RH side where it goes behind the rear master cylinder and RH rear set & lower fairing area. While re-installing mine the heat-shield seems to be closer to the edge of the lower fairing than I remember when the bolt that goes thru the RH rearset to the heat-shield is tightened.
Thanks in advance!
-John
Thanks in advance!
-John
