1 - 3 of 3 Posts
First, I was drunk. Both times. That said.
I pulled my engine to have adjustable cam sprockets done, I swore it would be simple plug and play when I put it back in making just a few things, nope.
I can't remember if there were any extra unused plugs from doing pair block off. I can't find the plug the rear break switch connects to. I can't find the plug for the radiator fan connects to.
Android sucks for letting me attach pictures.
Discussion Starter #2
Anyone know where the plug/harness for the fan is? I have been to service department at Honda. I've looked at wire diagram, short of pulling everything out, un-wrapping harness, and following the wires, I'm stuck.
Discussion Starter #3
Cheap wish.com rearsets didn't have attachment for rear brake switch, so it has been tucked in bike frame. When I pulled the motor, I just pulled plugs in good faith. Turns out the brake light switch and fan have same plug. That said. Found both problems. The other 2 plugs in question have to be pair block off plate mod.
1 - 3 of 3 Posts
