1 - 14 of 14 Posts
Items removed from 09 cbr1000, in excellent used condition. PayPal Only.
09-11 CBR 1000rr Bazzaz :
Z-Fi TC traction + qs + fuel [#T341]
TC Adjust / Map Select Switch
TC Active Light
qs is BOTH Push/Pull
$400.00 Shipped U.S.
Akrapovic Race Slip-on (Titanium can / Stainless mid / carbon hanger) Stainless mid is Jet-Hot ceramic coat inside and out.
Stock 09 Headers with Jet Hot ceramic coat inside and out.
$450.00 Shipped U.S.
I recently swapped a 2015 engine and harness into my 2008. I called Bazzaz to see if my 2008 ZFI/TC/QS system would work on the new harness, and I was told I needed to get a new Bazzaz fuel harness. They said 08 had some differences in the fuel harness. The invoice that came with my new harness was 09-11. After doing the swap, the only difference I found in the harness was a sub-harness that connected to one of the injectors and the TPS. So, 08 is a little different, but 09+ should work fine.
I believe my 09 headers and 09 Akrapovic slip-on should fit 08 CBR. I bet someone on this forum will have a definitive answer to that question;)
Thank you. I did some digging and it seems they should be the same unless it’s an exhaust sytstem for a model with ABS. Is that the one you have?
1 - 14 of 14 Posts
