1053cc fueling/Power Commander map?
370 Views 4 Replies 2 Participants Last post by  Butters51
I’m closing in on my first break-in rides at the track for my freshly built 1053 engine.
I have a Power Commander 3usb installed and it’s using a stock displacement Yoshimura slip-on map.
The displacement is now about 5% more and my guess is the fuel mixture is lean. The bike warms up much faster… a sign it’s lean, perhaps.
DynoJet map database doesn’t have anything with the 2mm high compression pistons I now have.
Does anyone have a custom map for this displacement I can try to input to get me by for a day or recommendations on how much fuel to add to the current map to ensure I don’t hurt the engine? Trying to avoid hurting valve seals or cracking a piston.
Thanks
Tire Wheel Fuel tank Automotive fuel system Vehicle
Reactions: 3
1 - 5 of 5 Posts
It won't be lean to cause motor issues. On my 1091cc high compression build, I ran a dyno on a 999cc map and was only very slightly lean from 10k to 13k. You can pick a map from Dynojet and scale the entire fuel table by 5 to start.
Perfect! Adding 5% to my current map was plan A, so I will start there. Much appreciated
It won't be perfect, because the Power Commander will not add 5% to the upper airbox injectors. It may run a little lean, but it will not be lean to cause damage.
Here is the AFR curve for my bike on a 999cc map. It had +12-15% fuel in the range that read slightly lean, but still perfectly safe. +2mm overbore is not a significant change to the displacement, and higher compression ratio improves engine efficiency, but does not cause more fuel to be used.
Rectangle Font Parallel Pattern Slope
Sincerely appreciate your help!
I saved the map that was in it and might go back to it after your extremely helpful information.
We added some fuel and you can smell it 😂
I will be testing it out this Friday at the track. Nice and easy day 1 and then oil change. Then let er rip!
1 - 5 of 5 Posts
