This is great info, I'm just wondering where you got the tire measurements?Many people do not realize this BUT the number on the side of a tire doesn't always mean what you think.
For example...
Pirelli Diablo Supercorsa SPV3 (DOT track day tire) 200/60 is 670 mm in diameter - can be used on the street AND track
Pirelli Diablo Superbike slick 200/60 is 662 mm in diameter
Pirelli Diablo Superbike slick 200/65 is 672 mm in diameter
Michelin Power Cup 2 (DOT track day tire) 200/55 is 665 mm in diameter - can be used on the street AND track
Michelin Power Performance slick 200/55 is 660 mm in diameter
Michelin Power Performance slick 200/60 is 675 mm in diameter
There is a 6.5 mm difference in rear ride height between the Pirelli and Michelin 200/60 slick results in VERY different handling characteristics not to mention the tire profile.
This is why it is VERY important to pick a tire that fits your needs and stick to it.
Already on it dudeDo you have rear shock height adjustment? Chain length altered or changed? Sprockets swapped?
I have gathered this info over the years. I have a small business setting up track motorcycles and tires are a big part of that equation.This is great info, I'm just wondering where you got the tire measurements?
Thanks.
I get what you are saying but in reality this isn't really any issue. Tires don't always measure what the side wall states, for example, the new 190/60 PIrelli Diablo Superbike slick actually measures 200 mm wide.I considered a 180/60 for the reasons mentioned but in the end I thought it would be safer to have the extra tire of the 190, for a couple reasons, especially on track.
While the 180 would probably be ok, I don't want that in the back of my mind.
Sounds good thanks! I prefer a 180 actually. Hopefully there are some sticky vendors for that size.@jehanzeb the 180 will work on a 6" rim but the profile will be slightly different but will work just fine. I am just exploring ideas to give you a bike that handles well with a tire diameter close to oem but have not made a determination yet.
I am leaning more towards the 180/60 at this point now.@jehanzeb the 180 will work on a 6" rim but the profile will be slightly different but will work just fine. I am just exploring ideas to give you a bike that handles well with a tire diameter close to oem but have not made a determination yet.
Diablo rosso corsa 2. 190/55 rear 120/70 front.@HP17 what size and model of Pirellis did you go with?
Yes yes sorry I meant sag not preload. And yes I had targeted 40mm up front with myself on the bike, with gear, but either my friend measured incorrectly or AJ at Paradigm measured incorrectly. Our measurement at the rear of 30mm agreed with AJ's measurement. I do know how to measure bike and rider sag, although I see why you would be skeptical lol.@HP17 yes I had mentioned to you before that you needed 40 mm rider sag front and 30 mm rear. This is not preload, as you mentioned. Preload is HOW you adjust the tension on the springs to get bike and rider sag. Do you know how to measure bike and rider sag? If not I can direct you, if you do I would like to know where your bike and rider sag are currently WITH gear. Sounds like the trackside tuner made changes in the direction I already suggested.
Thanks for the feedback after your trackday!So my track day went well with the new Pirellis, although to be honest I'm still not really happy with how the CBR is feeling in the corners. It feels slow to turn in, like it takes a lot of bar pressure.
Yea no problem! Interesting you are having a similar feeling. I will say though, I went for a street ride through the local twisties the other day, and the bike felt a lot better. Easier to turn, held a line well. Only change I made was putting the tire pressures back up to street levels (about 34 f and rear).Thanks for the feedback after your trackday!
I am feeling the same way on the turn in. Requires a lot of input to initiate a turn.
I am thinking a 180/60 might be the cure but have not mounted it yet.
Will post when mounted and tried.
