2011 1000RR. Finally got everything installed, weighed on 2 LB and 35 LB scales.
Stock 530 116 link chain 5.08 LBS
EK 3D GP 520 116 links 3.92 LBS
1.16 LBS saved
Stock 530 16T front sprocket .6 LBS
Renthal 520 15T ultra light steel sprocket .36 LBS
.24 LBS saved
Stock 530 42T steel rear sprocket 1.34 LBS
Renthal Aluminum 43T rear sprocket .596 LBS
.744 LBS saved
Stock sprocket nuts/washers X 6 steel .24 LBS
Pro Bolt aluminum sprocket nuts with SS inserts .068 LBS
.172 LBS saved
Total 2.316 LBS for 520 conversion
I also swapped out the stock rear rotor with a MMR style light weight rotor which saved another .75 LBS. The MMR version might save another .17 LBS.
Overall the weight savings was less than I expected. I spent $336 for those 5 items, replaced perfectly good chain and sprockets. I could have used the DID ERV3 chain and saved $40. It should weigh about the same as the EK 3D GP and the DID is almost as strong, but I wanted the black/gold EK.
I also grabbed a SpeedDRD. My speedo was accurate before the conversion. Now it reads 65 mph when GPS read 60 mph so I will dial in -7.7% correction.
1.16 LBS saved
.24 LBS saved
.744 LBS saved
.172 LBS saved
