1 - 6 of 6 Posts
I'm new to this forum and recently purchased a 2018 CBR1000RR. This bike was purchased at Copart and the ECU was missing. I would like to turn this into a track bike or something. I need to replace a few items including the ECU. However, I'm not sure if this is the model that has ABS. Also are there any other considerations for finding a replacement ECU? I've attached a copy of the front wheel; however, I'm not sure where else to look to confirm ABS. Thx!
Tire Wheel Automotive tire Motor vehicle Tread
2019 CBR1000RR SP
Here is a cut and paste from some older posts by someone who is no longer on these boards:
What is currently in your bike? I think for 2017 & 2108 -C12 and -L02 may be interchangeable for the ABS model. -A22 should be base if I recall.
L13 is SP (but I think I have seen an ABS with an L13) and -L72 is SP2.
The -LG2 and -LK2 should be 2019 ECUs.
You should verify part numbers are correct before purchasing any ECU’s
Hope this helps you out
CBR 1000 RR 2017 ABS SC77
On your picture there is the ABS captor.
You could also check as mention before if the break line go from the caliper directly to the master cylinder or check under the seat if the ABS modulator is present.
SuperMod
Let us know if you figured this out.
also, how was your experience with copart? was it hassle free? did you get a good price?
Discussion Starter · #6 ·
I called a few other dealerships and found out it was non-abs. The Copart experience was okay. Fees add up pretty quickly
1 - 6 of 6 Posts
