1 - 5 of 5 Posts
Hi,
would like advise,
1. do i need to adjust AFR - i have fitted a Yoshimure R77 with S-bend
2. if i do adjust the AFR - will the additional fuel and Air damage valve seats and piston rings in long run
3. ECU flash or PCV
a. ECU flash cost - USD490, the tuner willing to adjust Radiator fan values, Disable Exhaust Flapper motor and do dyno run and derestrict what ever necessary
b. PCV cost - USD450
Thanks
Hasan
Assuming this is for street.
Install PCV and download and use the map for that exhaust from PCV website, it will do the needed adjustment for you.
PCV more configurable than ECU in case you change the exhaust etc. It’s one time cost (you make the changes yourself on PVC or use appropriate map yourself) vs you have to pay to reflash ECU for any future changes.
Discussion Starter #3
hi
thanks, will the PCV or ECU flash harm the engine in the long run, or are these bike engines designed to take that additional fuel increase
regards
Hasan
hi
regards
Hasan
If the tune is badly incorrect you could destroy your engine. No different to any other car/bike tune.
If the tune is correct then it is no different to running a car/bike with a factory setup and will have no detrimental effect/
Discussion Starter #5
I am going for the woolich log box, as there are multiple options in the package, PCV is limited
regards
hasan
1 - 5 of 5 Posts
