2018 Honda CBR1000RR -- KCS Tune, Unrestricted, Akrapovic Ti header and Akrapovic Ti GP Slip-on.
Header and cat are finally off!
Bike is beating my ass! Haha
Anyone know what to TQ these header nuts to?
I’ll say this...
These Akro headers are a PITA to install and if anyone tells you different, they’re FOS!
Ive had these things on and off so many times to line them up and all, I can’t count!
And I’m no noob to modding via LT’s and pipes on bikes, Mustangs, Camaro’s etc.
I’d rather them been like OEM where everything is already in place, just bolt them up and go!
/rant
Header and Y pipes on.
Took 2 days working off and on to get to this point, so if you do this, plan a weekend!
Pulled ECU for KCS tune.
Removed rubber glued in ram air restrictors.
Removed electronic exhaust valve motor / electronics, and cables from under the seat.
But it was mostly lack of sleep.
I unbolted the radiator and pushed it forward, and then I unplugged and removed the fans.
I TQ'd every nut to spec and even got all the exhaust springs on with pliers.
But I suggest a spring hook to make life easier: https://www.amazon.com/Motion-Pro-08-0127-Heavy-Spring/dp/B000RG5UMA
I’ll say this...
/rant
I did other mods, too.Gratz on getting them on... Really not sure why all the problems, the wife and i had this knocked pretty quickly. loosened the radiator and things went pretty simple. The biggest pain was getting the springs hooked up.
Didn't remove radiator.How did you get them torqued? If you don't remove the radiator, can you get a torque wrench in there? Assuming you are using a wobble extension with a flex head socket? Does that not change the torque value since you're not coming at the nut straight on?
