Hi all,
I just picked up a liter of ATE Super Blue Brake Fluid to run in my clutch and brake lines. It says you can mix it with the DOT 4 fluid currently in my brake system, but should I drain out the DOT 4 first, then bleed from scratch with the super blue? Or... can I just empty the resevoirs and keep filling them until it runs blue out the bleeding valve?
Has any done it either way? Do you get the same benefits either way? Any opinions?
Thanks in advance
Thanks in advance
