Posting a new thread to clean up. Lots of good parts still available.
$150 - 2 michelin 19/67-420 16.5 slicks, each
$450 - Marchesini cast mag 16.5 rear wheel, hub, and slick, new (always stored indoors w/ tires)
$50 - Ano blue AFAM sprocket, 520 x 42T (fits Marchesini)
$40 - Horn and air dam
$25 - Front brake line assy (2 available)
$50 - Flasher/horn/brights switch, if I find all the wires.
$50 - Ignition key cylinder and 2 keys
$50 - Upper triple tree, tweaked, works fine.
$200 - 04-05 oem forks, axle. Presumed in good shape and straight
$50 - Subframe, tweaked but not too obvious.
$0 + shipping - blue/yellow junk tail fairing & vents.
$50 - RH clip-on w/ weights & bar-end, surface scratches on bar end
$50 - Throttle assy, no cables
$60 - OEM shock (needs recharged, LOL), 04-05
$60 - Complete rear brake, less res hose, pads almost new
$35 - Loaded swingarm, less the swingarm
$75 - LH blue/yellow fairing. Lots of rub marks, crack from slider hole.
$40 - LH flat black lower, big chip in plastic, no rash, no sticker.
$100 - RH blue/yellow fairing. Cut for slider, fallover scuffs.
$40 - RH flat black lower, partially cooked by exhaust.
$75 - Blue fender, scratches from installing wouldn't show in pic.
$75 - Blue/yellow tank shroud. Rub marks maybe through clearcoat, not through paint.
$20 - LH passenger peg.
$150 - 06 Gauge Cluster, < 13k miles. 1 broken screw mount, no needle
Pics to follow. As I said before, PM me with questions/offers, or just send me payment with a note specifying EXACTLY what you're paying for, and where to send it. Paypal address is . If anything needs clarification, please don't hesitate to ask.
