I had a similar issue with my 2022 1000RR and it turned out to be loose battery cables / Wires.. I tightened them up and it solved my issue .. I hope this helps and is as easy a fix on your bike as it was mine. Stay safe
Hey man, funny that this thread notified me through my email. I did wind up fixing this problem with a fuel pump. Tank was dirtier than what I could tell just looking in with a flashlight, once I dumped the fuel & took the pump out, the tank, filter, and pump were filthy. I took the tank off, bought fuel tank cleaner, spent the day cleaning the tank, I bought an OEM fuel pump off eBay (they should come with a new filter) and after it all went back together it ran like a champ from then on.Finally someone that is going through it very similar to me given the unfortunate circumstances. I am experiencing same issue on my 2022. I have 7,500 miles on it and it starts doing same thing after hard pulls. Once i start cruising through town is when it stutters and jolts and shuts off at lights. but when doing pulls its like it lags and has the delayed and inconsistent power delivery. only thing i have done to the bike is an akropovic gp slip on. no tune yet. now i did take the battery out when i did exhaust so as mentioned above could be electrical given flashing ABS and TC lights and the HESD light that pop up right as these issues start when riding. Also seems like not enough power to the starter. Any additional input very much welcomed. Thanks in Advance.
Did you have any issues with electronics at all? My cluster flashes those lights as mentioned and then i have the same issues shortly after. Im going to try fuel treatment as well. Im due for another maintenance anyway so i will have a buddy scope the tank to see if i should add that to the scheduled list.Hey man, funny that this thread notified me through my email. I did wind up fixing this problem with a fuel pump. Tank was dirtier than what I could tell just looking in with a flashlight, once I dumped the fuel & took the pump out, the tank, filter, and pump were filthy. I took the tank off, bought fuel tank cleaner, spent the day cleaning the tank, I bought an OEM fuel pump off eBay (they should come with a new filter) and after it all went back together it ran like a champ from then on.
No issues with electronics. Everything seemed to operate perfectly except for that shit i mentionedDid you have any issues with electronics at all? My cluster flashes those lights as mentioned and then i have the same issues shortly after. Im going to try fuel treatment as well. Im due for another maintenance anyway so i will have a buddy scope the tank to see if i should add that to the scheduled list.
