I have an excel document for calculating the proper brake master for a given caliper,.. PM and i will try and send it to you.Thankyou, I know it's all to do with piston size so instead of being lazy as I have been I will dig in. Thanks again
I have the Galfer superbike lines on mine. Two lines down from master cylinder wrap around forks and into caliper. The flare connection means you don't have to mess with copper washers every time the calipers come off.Which brake lines did ya’ll go with?
Hel ABS lines for now (brembo 19 corsa corta)... will assess after my first trackdayWhich brake lines did ya’ll go with?
