Clutch bleedong problem
Today i was bleeding the clutch on the 2005 fireblade after putting in fresh brake fluid.
At some stage the clutch felt more stiff than usual and after releasing some pressure i had to start the bleeding process again.
I kept bleeding at the bottom opening and closing the bleeding valve screw at the bottom but pressure never builds up on the clutch lever.
Air was coming out as i seen it in the bleeding tube i added to the bkeeding opening.
When the air stopped coming out it was pushing fluid into my bleeding bottle and the reservoir was draining. But pressure never built up.
What could be the problem and ho
w can i check it?
w can i check it?
