1 - 7 of 7 Posts
1000rr 2009
Hey folks
A bit of a odd one for ya, my clutch cable obscures the veiw of my odometer, is this normal? I cant see how I could re route it in any way, I'm thinking it may be the wrong cable. Can anyone else with 2009 show me their veiw ? Many thanks
262516
Hook 'em!
2017 CBR1000S1
I had a 2009. Clutch cable should not obstruct the display.
Clutch cable = 22870-MFL-000
Honda Cbr1000rr 2008
262580
the cluch cable should cross the cooler in a special clip. In the middle of the cooler. I had the same problem when I bought my cbr. Pre owner was probably lazy. so when they change it. Did they put the wire on the out side of the cooler. The result! the cable will be to long
1000rr 2009
Discussion Starter · #5 ·
Cheers pal, I don't have a cooler at the front like in the diagram, what year was your CBR ?
Thanks for your reply 👍
You may want to check if the plastic tab holding the clutch cable above the radiator is broken or not. If it breaks the clutch cable can drift around between the frame and radiator which will make it too long.
Reactions: CBRLeigh
1 - 7 of 7 Posts
