Another thread about crank no start. I hate to be on here asking this but I'm looking for help/suggestions. My issue is with the electrical diagnosis. I'm shit with a multi-meter. Don't know how to run down what is causing the issue. Here's the situation
: Bought bike from member here about 7 years ago. Because of issues with my landlord I hadn't been able to work on it. Supposedly it was running when purchased. My buddy bought it for me cause the member wouldn't ship direct. My friend said he rode it when he got it. Then he shipped it here from back east. I couldn't get it started when it arrived (low battery). Feel like the seller misrepresented the actual mileage from looking at the wear on it, but can't say for certain. Mileage is just at 4,000ish. It was a track bike and typical track shit was done to it. Anyways, I stripped it of a lot of the upgrades, sold those, and it then it sat. Fast forward to now. So far I've done:
BTW:When cranking I have a touring Harley battery with a full charge connected via jumper cables to the new battery in the bike. I do this because our batteries are so small and lose quite a bit of CCAs after a few attempted starting cycles.
:New plugs
:New airbox
:New Radiator
:New oil (3.5 qts), new filter. Sight glass shows full (on stands).
: Power commander removed
:Injectors removed and cleaned
:New fuel
:Fuel pump primes. Tried a different fuel pump and it also primes
:Old new battery, crank no start
:New New battery, crank no start
:All the fuses I can think of have been checked
:Starting Fluid sprayed straight into the cylinders. Crank no start.
rimary Injectors cleaned (again I think because couldn't remember 100% if I had done it but 99% sure I did)
:Fuel cut off relay jumped and key on. As per manual, fuel hose to secondary injectors disconnected Fuel does flow (from both fuel pumps I have). Did not have a container to measure the exact amount, but it was a fair bit
:Continuity for all injectors tested and good.
:Voltage for primary injector connectors good and testing within range
:All fuses replaced, even though the ones sitting in the package look as oxidized as the ones in the bike (cleaned with steel wool).
Now, when I started this process, bike would light up but wouldn't crank (there are no headlights on ATM. BAS is mounted in place). Turned out to be a missing clutch switch on the perch. Which makes me wonder how he had this wired to start before and why this was even missing. Borrowed a switch from a fellow member (as well as the radiator - thanks to Mr Stott). I couldn't get it into neutral (had no rearsets on it) and had to go through 2 sets to get the damn thing to go into neutral. Now it will crank both with the clutch pulled in and while in neutral. I do have an Fi light. Not sure if that would cause a no start.
ECU replaced with another unit. Thought to be good but not 100% sure.
Some of my questions to start are:
: Could missing, incorrectly routed hoses cause a no start situation? Outside of the fuel line, it looks like they are both breather hoses. Also looks like the evap canister is missing. Checked again, this is a non-California bike so pretty sure it did not have one.
Need to check all the terminals at this point I guess. I think I might be better off buying a known good harness and replacing everything (time-wise).
I'm going to start going through the list but jumpering connectors and checking continuity are just outside of my current wheelhouse. Any help is appreciate. Pictures help immensely as well. Thanks to everyone in advance who tries to help on this.
:New plugs
:New airbox
:New Radiator
:New fuel
