I just received my PCV and Auto tune from SupebikeSupply(thanks to Mary!),after more than 10 hours of rewiring and test riding,i am totally dejected now.
First of all,the PCV works well,i can feel the power difference wtih different map uploading.the problem of my auto tune was i see nothing changed of my base map after test riding!
at first ,i think because the auto tune was automatically changed the map "on the fly",maybe it can not save the fuel trims to the base map,so i can not see anything changed of the base map when i stop riding and shut off the engine.(please let me know the truth,am i right?)
second,i add SPST switch to my PCV,like the user guide said,after riding,if i toggle back the switch from "learn" model to "base map" model,i should see the adjustments in the "Trim table",but in fact,the whole trim table are still all zero ,the auto tune DO NOT work just like my butt-dyno want to say
i have tested the o2 sensor,the led light blink rapidly first,and pause forever,did not flash like the user guide saying,the location i lived is 120 feet of elevation,i think it should means zero number of the flash,so it should be ok for the o2 senor,am i right?
i also tested the cable between PCV and auto tune,it works perfect,no open.
i did not connect the speed to PCV,but i messed the gear calibration table of PCV before,i already re-install the PCV software,but still a mess,and the software always showed 1th gear.
the pcv and auto tune is proper powered i am sure.and i have checked the wiring for more than 10 times,nothing wrong there.
Mr dynojet or anyone,please give me some clues,i dont think i am so lucky to get a brand new fault product of dynojet company.any opinions will be great appreciated!
