1 - 20 of 47 Posts
This week I am getting my first fireblade, a 2017 with stock exhaust. I plan on putting on a TOCE aftermarket slip on and an ECU flash. Im just curious if I need to have a servo eliminator along with a flash or will I just leave it unplugged when I put my new exhaust on.
Discussion Starter · #5 ·
It's possible to get a flash with a servo delete. You need to talk to the person that's selling you the flash
Okay I am getting it done through the same company that I’m buying the exhaust it’s a 100 dollar discount but when I try to select a servo blocker it cancels out the ECU flash and vice versa. So I would say you are most likely correct I’ll email the company though to see what they say
Please don't put a Toce on it. The stock exhaust is very high quality and the $$ spent on the exhaust could instead go to a tune that unleashes the stock bike and the stock exhaust.
Once unrestricted it sounds really good, and again, the stock exhaust is actually a very well designed and engineered system. Oh and it's titanium.
262447
Discussion Starter · #7 ·
While you make a very good point I like the look of the Toce exhaust personally, and if I don’t care for it I can always put the stock one back on
You should not be buying/paying for an external device to spoof your servo. Anyone flashing your ECU should be able to turn off the servo in the ECU. If they can't give your money to some else that can.
17 CBR1000RR SP
Exhaust on the Base model is stainless not titanium. The SP1/2 models got the titanium muffler and gas tank.
With the TOCE you will save a few pounds but increase the noise, probably beyond legal limits. You will need the tune to keep the bike from running lean. You can also get the throttle valves to open fully if yours is a USA model.
Hook 'em!
2017 CBR1000S1
So I have the SP
Muffler 18310-MKF-D40
Headers 18150-MKF-D40
Same part numbers for both Standard and SP
The fuel tanks are different.
That's why I got hold of a stock muffler for mine it's quite a nice stock pipe, with the cat and exhaust servo gone and now a dyno tune I'm well happy with fairly budget usable performance upgrades.
Hook 'em!
2017 CBR1000S1
Yup, I don't see the point of removing a $2,539.28 titanium muffler just because it's OEM.
Discussion Starter · #15 ·
When I bought my exhaust I also purchased an ecu flash so that should fix the running lean. I saw a couple companies when they do the flash they increase the rev limiter, this one said it was optional but I think I want to any idea what they increase it by?
They most likely increase it by 600 rpms, from 13,200 to 13,800 (what the non-nerfed bikes are factory set to).
I set mine to 13,800.
Oh for sure. The stock US tune is heavily restricted from 10k rpm to redline. Without any "custom" tuning an easy 10+ hp is available just from derestricting/allowing the bike to go full throttle.
Really though for day to day street riding or commuting, probably won't make a big difference. On the track or if doing a half mile pull to 170, big difference.
Discussion Starter · #20 ·
Great to know, I’m definitely glad that I’m getting it done then.
1 - 20 of 47 Posts
