1 - 3 of 3 Posts
Does anyone have info on ecu 's I have a 929 that I was told the ecu was bad. Is there an ecu that's interchangable like a 1000 rr? Is there a way to test the ecu ,also what's a bizazz?
17 CBR1000RR SP
ECUs are bike specific unless you are in to reading schematics and changing wiring and connectors, then it will only work if the options are the same on the donor bike and yours, injectors the same size, fuel, pressure, sensors, etc. Best to just get one made for the bike.
1 - 3 of 3 Posts
