Big problem need some help. 06 cbr 1000 K&N filter with aftermarket pipe. Around the mid 5k rpm range it bucks around and lose's its power. Any Ideas would be Great. Swapped Throttle Boddies to rule out TPS also swapped Ecu
a speed sensor. What does that control. I dont know what other info i can give you. I gave the only symptoms its doing. I have a Power commander tried to remap it,still did it. Took it out still same issues. the shop said the secondary injectors arent coming on. When he hooked up a volt meter to the Tps its not changing when you turn the throttle.
once i get home i can tell you what the 11 blincs code is, can remember of the top of my head. ok here is
11 blinks = velocity sensor (VS) circuit mal fuction, Loose or poor contact on VS sensor conector, Open or short circuit in VS sensor wire, Faulty VS sensor and the HESD will not work causing the problem you are having. :th_salute:
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
