Not sure which to recommend for your 08... but beware of turn 8(ATE).:stirpot:
Unfortunately, Motovation only offers no-cuts for the '04-'07 1000RR.But, if you really are set on no-cuts, call Brad (lexus rx) up at superbike supply and get some Motivation no-cut sliders. They seem to be one of the top recommended no-cuts.
Yeah, a couple of the guys from the other forum i'm on (Jaxsb) have dumped down at turn 8, it's a bitch! Summit Point had a real nasty one also on the Shenandoah cirquit last time I raced there, I about smacked into the wall on my 5th lap :beat:Not sure which to recommend for your 08... but beware of turn 8(ATE).:stirpot:
How hard is it to cut without messing up the plastic? I've seen a few cuts where it has cracked outwards after time.Woodcraft as I mentioned above. They have more puck material and don't stick out as far as others. You'll find they come highly recommended.
Not hard. You just use a 2" hole saw drill bit. There are a few threads on it.How hard is it to cut without messing up the plastic? I've seen a few cuts where it has cracked outwards after time.
