Was trying to prep the bike for the track and went to pull some fuses and realize the fuse box is behind the left side middle panel rather than under the seat. What a pain! I'm assuming this is due to having to move things around because of the real gas tank location/underseat exhaust. Next time, I'm going to experiment with just pulling the small black inner "ram air cover". It's just two black snaps, and I think it might be possible. Not what the manual says, but I think I can rig it. :wink:
Additional note for anyone that usually pulls fuses on lighting for the track: On the 929 I had it all rigged up to do this easily while retaining the gauge (I every once in a while like to check speeds on the straights). On the new RR the taillight and gauge are on the same fuse, so I went to just pull the plug on it and realized you can't get to it without pulling the whole tailsection off! Grrrrr. I figure since it's L.E.D.'s I'll probably just put the vinyl over it and call it good. Shouldn't have to worry about it overheating like a regular bulb can.
