1 - 12 of 12 Posts
I am currently converting my 07 into a track bike. I’m wanting to delete the headlights/ headlight switch when I put on aftermarket clip ons. How difficult is this? Will I need to tap into the main harness
Discussion Starter · #2 ·
Tech Moderator
Bridge clutch switch wires together.
Tech Moderator
Bike will not start or run without clutch switch connected.
1. remove left-controls sub-harness
2. in open connector where sub-harness was connected, bridge 2 terminals that used to go to clutch switch
Make a jumper like this and plug into where subharness used to connect, although I think it needs to be male terminals.
It'll look something like this when installed. Look in manual for 2 wire-colours that goes to clutch-switch. In connector with 9-terminals or so.
Tech SuperMod!
I don't recommend deleting the clutch switch, because the bike uses separate ignition tables for neutral/clutch-in and clutch-out so your idle will be high because the bike is running ~10 degrees of advance at idle instead of ~4 degrees unless you fix it with ECU flash.
Tech Moderator
Which ECU line does the map-switching? On pre-'08 bikes:
B22 - grounded by neutral-switch ON, which also provides ground for starter-solenoid
B23 - grounded by clutch-lever squeeze OR sidestand switch UP
Seems internal safety logic inside ECU is this:
IF neutral-off AND (clutch-lever released OR sidestand down) THEN kill sparks
so if I shift to 1st with clutch not squeezed OR sidestand down , it kills engine
since sidestand-switch is connected in parallel with clutch-switch, yeah no bypassing clutch-switch needed. Just bypass sidestand-switch to show in UP position and it grounds B23 same as squeezing clutch.
Tech Moderator
So basically the the bike thinks the clutch is constantly pulled in but that’s ok with 07 ecu?
It's a safety indicator to ECU as follows.
First priority is neutral-switch. If it's in neutral, doesn't matter one bit what else is going on, bike will start and run.
When neutral is NOT on, B23 line is grounded by either clutch-squeeze OR sidestand up. They both connect to that line and ECU has no idea which one is connected.
So no, don't need to bridge clutch-switch. Just short side-stand switch wires to indicate UP and that should work.
1 - 12 of 12 Posts
