1 - 6 of 6 Posts
Hi
2004 Lights have never glitched or anything to indicate its on the way out or anything but now, the headlights don't light up. if I hit the push to pass then it works, if I hit the light slider to activate high beam and press the flash, both light up but if I let go then it goes off. So I have no riding light in front. I've swoped the bulbs around, even swoped the plugs around, checked fuses, seem ok. Short of taking it to an auto electrician, what else could I try to test with my very limited skills.
Where are the relays for the lights situated? it was just by luck I came across the fuses and the diagram on the lid is still visible..
2005 CBR1000rr
Don't know if the bike has been out in the weather much. But switches can get corroded and not make proper contact, especially after 18 years. Since the lights actually work in some instances, it could just be the switch. I've never had one apart, so I can't say what they are like inside. Might be worth a look to see if anything can be cleaned up.
shot thanx for that tip. will def check it out during the course of today. I hope its not gona cost me an arm and a leg to fix.
This and check wiring connectors under the dash area. Can corrode due to water intrusion.
17 CBR1000RR SP
The other replies have probably pin pointed the problem. If your Lights are lighting pushing the flash button then it is very likely the switch contacts need cleaning.
Good Luck.
Discussion Starter · #6 ·
Thanx so much. Really appreciated the comments. Problem was traced back to the start switch on the right thumb. I was getting no power on the white at the relays. Contacts in that unit was worn out and corroded from age I guess. cleaned it out, McGyvered the thing abit, lightly with nylon brush and the contact cleaner..etc etc.. Lights are 100's again and so is switch. waterproofed it again aswell. good to go for another 10 years.
Tire Fuel tank Wheel Automotive fuel system Vehicle
1 - 6 of 6 Posts
