When installing new fork seals, there is a ring (called a backup ring) that sits against the seal. On mine, one side of the ring has a groove machined into it and the other side does not. I've done endless research and cannot find a definitive answer as to what side of the ring sits against the fork seal.
Whoever did the fork seals before me had the ring in one fork one way, the other fork was the other way. So I can't go by how I pulled them out.
Also, I'm 99% positive I'm putting the seals in correctly, but to be sure- does the chamfered side of the seal face down towards the wheel or up towards the handlebars? Again, endless research and no definitive answer.
Please if anyone knows for 100% sure, let me know. You'll be helping me immensely.
I've attached some pictures. First one is the back up rings, shows both sides- grooved and not grooved. Second is both sides of the oil seal, labeled A and B for easy reference. Third is the oil seal from a side angle, showing the chamfered side.
