Up to date list as of 11-17-15:
Micron Slipon - $125 shipped
Atech Carbon Fiber Intake - $200 shipped
Ohlins Shock - $650
Penske Triple Clicker - $600 shipped
Speedo Healer - $50 shipped
Woodcraft Clutch Cover Protector - $80 shipped
Repsol Orange 06-07 HRC Link $75 shipped
Repsol Orange Rear Rim $ 175 Shipped
Dan Kyle / HRC Full Race ECU 04/05 - $300 shipped
Hunter Orange Fairing Stay - $120 shipped
Hunter Orange Aftermarket Stator Cover - $120 shipped (OR $200 shipped for matching Fairing Stay and stator cover)
Has small mark on it (pictured)
Rectifier - $40 shipped
Bazzaz GP Shift Quickshift Sensor - $200 shipped
Bazzaz shipped me a new head unit and sent a newer quick shifter with it when replacing my broken head unit so I have two quick shifters now.
Ohlins Titanium Spring - $300
Fits NON-TTX Ohlins Shocks. Sprung for lightweight rider. ~150-165lbs
Metallic Dark Blue-ish Black OEM Honda Seat Cowl (some scratches) $50 shipped
Blue and Yellow Tank Shelter with Carbon Fiber Inserts
Great Condition. Comes with CF look tank pad. Will not part out the inserts, they are epoxied in place.
$160 shipped
Near mint headlight. Has all tabs! - $150 shipped
Rear brake with lightened bracket - $50 shipped
Rear brake with bracket (x2) - $45 shipped
White Aftermarket Clutch and Rear Brake Lines with purple banjos - $50 shipped
Blue Aftermarket Rear Brake Line - $35 shipped
Heat Exchanger - $40 shipped
Race Upper Harness (x2) - $40 shipped each
Blue Lightech Keyless Gas Cap - $80 shipped
OEM Horn - $20 shipped
Oem Shock Linkage (x4) - $40 shipped each
Radiator Brackets (x3) - $20 shipped each
OEM Rear Rotors - $35 shipped each (x4)
Wave Rotor - $100 shipped
Tank Inserts - $15 shipped each
Upper and Lower Fuel Rails - $30 shipped
Hyperco Spring - $50
Spring would work great for a 250lbs rider.
Ohlins Spring (like new) - $80
Spiegler Aftermarket Black Clutch Line - $50 shipped
Kill Switch (x2) - $25 shipped each
Steering Dampner Mount - $20 shipped
Axle Adjusters - $15 shipped
Trunk and Gas Cap Lock with one key (no ignition) - $80 shipped
Ignition and trunk lock set with two keys (no gas cap) - $80 shipped
Ignition Lock with one key - $60 shipped
Trunk and Gas Cap Lock with one key - $80 shipped
Stock Passenger Rear Pegs Mint Shape - $50 shipped
Turn Signal Flasher Relay - $25 shipped
Stock Rearsets (need pegs) - $40 shipped
Radiator Fan - $40 shipped
Sprocket Cover (x2)- $30 shipped each
Axles - $20 shipped each
Aftermarket Reservoirs - $25 shipped each
Side Inserts - $30 shipped
Right Side Rearset (needs peg) - $30 shipped
Rearset Heel Guards - $20 shipped
OEM Stock Levers (light rash) - $20 shipped
OEM Stock Levers (clean) - $35 shipped
Stock Rear Brake Reservoir - $20 shipped
Kickstand (with wiring) - $25 shipped
Kickstand (no wiring) - $20 shipped
Sato Rearset parts - $15 shipped
Vortex Rearset parts - $15 shipped
CRG Adjustable Levers - $200 shipped
Clear Stainless Steel Aftermarket Rear Brake Line - $30 shipped
Galfer Rear Brake Line Kit - $30 shipped
OEM Clutch Slave (x2)- $20 shipped each
Gilles Shift Support - $100 shipped
Cush Drive Rubbers - $20 shipped
OEM Cush Drive with Aftermarket Sprocket - $50 shipped
OEM Cush Drive with Aftermarket (Renthal) Sprocket - $50 shipped
OEM Cush Drive with Aftermarket (Red) Sprocket - $50 shipped
OEM Cush Drive with Stock Sprocket - $50 shipped
Upper Triple Clamp - $50 shipped
Brand New Chrome Stator Cover - $50 shipped
OEM Headlight/Tach Harness - $30 shipped
OEM Black Shifter Lever - $20 shipped
Heat Shield - Free with any other purchase!
Air Funnels - $20 shipped
Front and Rear Axles - $20 shipped per axle
Laptimer Beacon - $50 shipped
