Motor does not have to be running to adjust the CCT. Loosen the lock nut, and while rotating the motor by hand (remove timing hole cover), finger tighten the CCT and back it off 1/4 turn then tighten the lock nut.
Turning the motor over by hand takes the drive slack off the cam chain as the motor would while running.
