:welcomesign:
Good point. Also if it is a Titanium setup the headers will be a different color. Plus you can tell the difference from a Akrapovic Header and a Stock header:thumbsup:Full systems have a carbon fiber heat sheild that say akrapovic on the right side by your leg and all the spring clips on the headers say akrapovic just look underneath the bike. Oh and :welcomesign:
Usually OEM headers look pretty nasty compared to aftermarket on most bikes you will see some kind of flapper joint infront of the mufflerGood point. Also if it is a Titanium setup the headers will be a different color. Plus you can tell the difference from a Akrapovic Header and a Stock header:thumbsup:
Ask the old owner. Hopefully he's got some maintainence history w/the bike.He said the easiest way
Unless you live anywhere in the U.S. other than Cali. No converter on 49 state bikes.Pull off the canister and downpipe. Stick a long straw or some fish tape down there. Itf it hits something, that's that catalytic converter.....slip-on. Or just get it dynoed.
+ 1000other than the visual by a trained eye. most replacement headers have a flange bolted to the cylinder head that the pipes slip over and are held with a spring. the stock unit its all one piece
