when installing the integrated taillight can it be done without resisters, and if not where is the best place to locate them?
I went this way . But on since this is the 06-07 mod area..Assuming he has that year.The flasher is in the left upper cowl area.. :thumbsup:Or you could just spend $15 and do it the right way.
VFX flasher
Its a bit of a pain in the ass to pull all your fairing for the install as it goes right between the headlights.
But it will give you a stock flash rate without having to use resistors that could melt whatever they are touching.
What he said. I used resistors with mine, mounted them inside the tail section, they're small.yup it can be done withuot them. They will just blink a lil bit faster. I didn't use them when i did mine.
Werd!Clear alternatives rear for mine, don't use the resistors they get to hot. If u don't like the fast flash call brad and get the plug in relay for leds, problem solved. 06 is behind the left cowl easy install and cheap fix.
+1Werd!
Just call Brad and tell him to make it happen
Yeah...OR you could do it perfectly fine the easy way...no resistors. I did it and the kit and everything took 45 minutes to install and looks AWESOME. Oh and it was like $70 shipped to me TOTAL.Or you could just spend $15 and do it the right way.
VFX flasher
