This is a composite picture I use on Instagram when people ask about GP shift on 2017/18/19 using OEM Quickshifter and OEM rear setsWhere do you get that cover?
I just called a bunch of local shops for custom carbon fiber pieces to make that cover (based off of Taylormade's design) but I was quoted like 2k lol. I can't find any aftermarket covers for it either. It would be super easy if someone had the part I could borrow so I could make a mold out of it (2014 1000RR).
Also, what's up with the ecu pic? lol
I flipped my shifter and in GP shift it won’t shift from first to second without the clutch. After that all gears shift without the clutch. Has anyone seen this before?Yes, flipping the shift rod accomplishes the task... but you will need to cut/modify the sprocket cover, or remove it entirely (not recommended by some).
