Malfunction indicator blinking
812 Views 5 Replies 3 Participants Last post by  empangup
I installed Akra Evo full system 2 days ago. When i ride, the Malfunction Indicator Light blinks continuosly. Is it because i removed the stock header cable when installing the exhaust?
1 - 6 of 6 Posts
how many times does it blink?
WHENEVER MY BIKE START THE MALFUNCTION INDICATOR WILL ON. WHAT SHOULD I DO???
Did you take the servo out or just unhook the cables. If you just unhooked the cables make
sure that the arent binding on any thing and move freely.
You can unhook them at the the servo and totally remove the cables but leave the servo in so that you wont get the error when the bike is running.
I totally remove the cable man. Right now the cable stick together with my stock header after i remove it from the plug (not sure how to mention it).could you be more specific regarding the SERVO IN?
my malfunction indicator back to normal after the mechanic fixed it. thank....
1 - 6 of 6 Posts
