Need some help
1115 Views 11 Replies 7 Participants Last post by  oipalc
What's up guys I need some help my cousin went agaisnt what I said about buying a Suzuki, anywase he bought a 2002 gsxr 1000 and he has no mechanical skills so here I am doing it for him.
When u hammer down on the throttle and rev it up the rpms want to stick around six thousand, if udown shift real quick the rpms will go back down. Could not having a packing in the exhaust cause this problem with it only being the can??? Or is there something else going on? Your help is much appreciated thanks slot.
1 - 12 of 12 Posts
The problem? It's a Suzuki. It might redline at 6k?
I think he is saying its sticking (won't go down), but not really sure
It's sticking around six thousand rpms when u let off the gas. But onle if u where riding hard, hey I'm just tryin to help him I got my 1000rr
Open the bike and check the throttle cables, Might be a kink in it + it's a SUK!
I'm pretty sure it's not the cables say it's stuck at six grand and u downshift then it will b fine
Got me! Like I said it's a Suk:popcorn2:
It has to be something with the cables, their really is no other way it would stick.
Is it sticking their and not moving at all, even if you try to give it more throttle without shifting up or down? Or is it just when it is reving down that is gets stuck at 6k?
does it have a power commander? are you sure its not a 01 i believe the 01 (maybe the 02 has it) still had a start enrichment on it (choke whatever they call it on it) make sure he isnt leaving that on
very good point, I didnt even think about it having the choke. I am so used to not having one. :beat:
if you try to give it more throttle its fine, when its reving down is when it gets stuck the actual throttle grip closes all the way thats whay i dont believe its the cable
What are the chances you could get a video of it?
1 - 12 of 12 Posts
